by Tornado-Saq Valued Contributor
Valued Contributor
4G+ on S10 Plus
Hello, just wondering if anyone can help.  Recently got an S10 Plus and the signal is only 4G and 4G+???    It was 4G+ on my S9 Plus and also it is currently 4G+ on my Tab S4.
I believe there is an issue with the 4G signal (I am getting 4G) on the S10 Plus and thread something on a Vodafone forum as well?
Can anyone assist?
30 REPLIES 30
Re: 4G+ on S10 Plus
4G+? What's wrong with that? It's the best you can get at the mo'.
Re: 4G+ on S10 Plus
Hi @Tornado-Saq
Have you checked your local network for problems?
Valued Contributor
Re: 4G+ on S10 Plus
Hello @Northerner .  Thanks for the post.  I have, all is working well.
4G is fine but for some reason 4G+ doesn't seem to be coming on.  It has been on my s9 Plus and is currently showing on my tablet.
just a little surprised it hasn't shown up.
Valued Contributor
Re: 4G+ on S10 Plus
@XRaySpeX    What????
Re: 4G+ on S10 Plus
@Tornado-Saq   Is it causing a issue if it’s not showing?
Valued Contributor
Re: 4G+ on S10 Plus
@Chris_B   It's not causing any issues.  I just don't know whether it is active or not?  Would be odd to upgrade the phone but the function of faster speed is not available on the newer phone?
Been on to the Live Chat facility and asked me to go through settings on the phone that don't exist so think they just couldn't be bothered.  Must be really busy or something.
Re: 4G+ on S10 Plus
Hi @Tornado-Saq
  • Sounds simple, but have you tried restarting your phone?
  • Can you enter *#1234# into your dialer, then post the three sets of numbers
  • Are you on PAYG or pay monthly contract.
Lastly did you get the phone from EE?
Valued Contributor
Re: 4G+ on S10 Plus
@Northerner  it is a SIM only on EE. Done the restart etc.
Screenshot_20190525-203648_DeviceKeystring.jpgNumbers
Valued Contributor
Re: 4G+ on S10 Plus
@Northerner image doesn't seem to be showing up so I'll type it out:
Version
AP : G975FXXU1ASD5
CP : G975FXXU1ASD4
CSC : G975F0BE1ASC8
Model : SM-G975F/DS
Reception shows  Vo)) LTE1   4G
Re: 4G+ on S10 Plus
It takes time for your pix to be approved by the Mods.
Re: 4G+ on S10 Plus
Re: 4G+ on S10 Plus
So did I!
Valued Contributor
Re: 4G+ on S10 Plus
Thanks.  Didn't realise.  Hope it does help.  Tried uploading the image to show the signal on my tablet, but keeps stating an error because of some HMTL or something.
Valued Contributor
Re: 4G+ on S10 Plus
Hopefully it loads
Screenshot_20190525-222307_One UI Home.jpgTablet Signal
EE Community Team
Re: 4G+ on S10 Plus
Hi @Tornado-Saq,
Welcome to the community 🙂
Where did you buy the phone from? Because it is not from EE, it might have slightly different menu layout depending on the software.
Do you know what settings the Live Chat guys were trying to get you to check?
Alex 🙂
by Ace Contributor
Re: 4G+ on S10 Plus
some phones don't show 4g+, just 4G, is this one of them?
Valued Contributor
Re: 4G+ on S10 Plus
@Alex_S  Hello and many Thanks.
I bought it from a friend who had it as an upgrade from EE?  I have checked with another SIM and it is locked to EE.  Just tried again and it is definitely locked to EE.
He was asking me to go through Mobile Data Settings and locate VoLte but I couldn't this anywhere.  He then asked to go on the voice settings to locate.
I mean don't get me wrong, the phone works fine.  Just a little confused about the 4G+ signal.
@chistery   I am just wondering whether that might be the case but I'm still getting the 4G+ speed but it just isn't showing it as that?  I've also read Samsung are aware of certain signal issues with the new released S10 phones.   Not sure when the next update is though.
EE Community Team
Re: 4G+ on S10 Plus
Hi @Tornado-Saq,
You can use our phone pages on line to fine the menu settings on your phone.
It will talk you through the settings depending on which software version your phone is on.
You can then check how the phone is set up.
Alex 🙂
Valued Contributor
Re: 4G+ on S10 Plus
@Alex_S   Thanks for this.  Got to APN type but doesn't let me type default and only allows me to choose options.  I went on setting up the Internet.  I'll wait for the next Samsung Update to see if that changes it.
