by KarenRobson68
New Member
4G not working
I am having trouble using my 4G. It is not working while using any apps however does work with iMessage. I have turned on and off reset network settings but still no luck. I have been on another forum and clicked a link to see if the 4G works when checking the amount of data I have. Could someone please help
Re: 4G not working
Hi @KarenRobson68
Try logging into your MyEE app then - Settings - Content Lock - change this to off. Then restart your device.
It should now work.
Thanks,
Re: 4G not working
Hi @KarenRobson68
Welcome to the community.
Is it mainly social media apps that you're having problems with.
Have you tried @Northerner's tip?
