by Doug71
4G not working on I-pad
Hi, I'm having problems with my 4G connection which started yesterday meaning I can't connect to the internet, social media, use Googlemaps etc. unless I have wifi. I've turned the i-pad on and off a few times now, switched Airplane mode on and off and also Reset Network Settings as per other posts here. None have worked. Any other ideas/options (and yes my bill is all paid up.)
by Brilliant Contributor
Re: 4G not working on I-pad
Hello @Doug71,
Welcome to the community,
Are you not getting any signal at all with your sim card? Have you taken it out given it a wipe and put it back in to see if that solves the problem?
It could be that you need a replacement SIM card, which you can do online or by going into an EE store:
https://myaccount.ee.co.uk/order-sim/
by Doug71
Thanks Shockwave - have done the Sim Card too.
Looks like I'd better order a new one then.
@Doug71, You are welcome, glad to help and hope that resolves your problem.
EE Employee
Hi @Doug71 and welcome to the community.
Please do let us know how you get on.
You can pop into your local store to perform a SIM swap.
Many thanks,
Lee
Recent solutions
