by Alicel97
4G and EE
My phone won't connect to the 4G or EE network it just keeps saying searching. Please help
Re: 4G and EE
You will need to give a bit more information as your question is very general.
  • What phone do you have? How long have you owned it and did you get it from EE?
  • Are you an EE pay monthly customer or PAYG?
  • If PAYG when did you last make a chargeable call or txt?
  • Are you on EE, Tmobile or Orange?
  • Does this problem happen in more than one location?
  • Have you checked your local mast for issues here
Lastly if you have an iPhone then try resetting your network under settings.
