by rovex40 Investigator
4G OK, H+ dead
I have a Galaxy S8+ (although the issue still occurs with other phones). Using 4G data is fine, the speed is variable, but it always works. H and H+ however seem like they are dead. Nothing works, not app data, not tethering nothing. There is just no throughput even with a good signal.
Any ideas? Its especially bad in the EX2 area.
by Star Contributor
Star Contributor
Re: 4G OK, H+ dead
EX2 is a very last postcode area, a more precise location would assist us helping you.
When do you find yourself on 3G as there is 4G coverage in the area?
Re: 4G OK, H+ dead
EX2 7AA is the main location, but it seems to be anywhere that H or H+ is used.
4G is a bit flakey in that area, so it drops to H quite often, but suddenly goes back to a strong 4G for no apparant reason.
EE Employee
Re: 4G OK, H+ dead
Hi @robex40 and welcome to the community.
I have just looked into the local mast and can't see any issues that would create a problem for you.
Please do give customer services a call and they will be able to investigate this further.
Many thanks,
Lee
by Star Contributor
Star Contributor
Re: 4G OK, H+ dead
The mast in theTopsham road roundabout near Beefeater appears to be legacy but apart from that I can't see why 3G doesn't work in your area. As Lee has said, maybe customer services could assist more.
