by jacqueline0 Valued Contributor
Valued Contributor
4G Max Plan
Is the 4G Max Plan still available to buy for use in USA with free calls to UK. I have aready got this plan and now want one for my husband
Thanks Jacqui
Solution
Re: 4G Max Plan
@jacqueline0  It’s available still but only as a full contract.  It’s not available as a sim only tariff any more. You can though get a sim only and purchase a add on that gives you this.
Have a read >THIS<  about EE Go Further add on.
by Ace Contributor
Re: 4G Max Plan
The Max Plan is still available for handset contract only.
The SIM only version is no longer available, and will require the "Go Further" roaming add-on to enble "max-like" roaming.
See the link below:
https://ee.co.uk/help/help-new/roaming-and-international/roaming-data-add-ons/go-further
W
Solution
Re: 4G Max Plan
Valued Contributor
Re: 4G Max Plan
Thanks very much
