by JoeHarrison Investigator
4G Mast Location
Hi
Does anyone know a web site where you can enter the Tracking Area Code (tac), Cell Identifer (CI) and Physical Cell ID of a 4G mast and it returns the masts location.
I am after something like http://cellidfinder.com but for 4G.
http://cellidfinder.com only does GSM.
Thanks.
8 REPLIES 8
by Profile closed
Not applicable
Re: 4G Mast Location
Ask @XRaySpeX they might know
EE Employee
Hi and welcome to the Community @JoeHarrison
This goes way over my head 🙂
Maybe @Jmitchell, @Chris_B or @Northerner can assist,
Hope you get sorted.
Many thanks,
Lee
I don't think there is any comprehensive location map as I have asked EE about this before. It's all top secret.
I have searched my local council local planning which can give you info on applications.
@Lee_H   Perhaps @Profile closed might know as I've never tried looking.
I do know that there is no point in asking EE tech as I've been told by them they thay do not disclose this information.
@JoeHarrison @Lee_H
Ive just found THIS site but it's not mobile phone friendly.
by Profile closed
Not applicable
I've no idea sorry.
Many of those cell mapping tools are often not very accurate anyway as I believe they only map cells using measured signal values from handsets.  Also I remember looking at one that said there was an EE mast near me which I know doesn't exist.
That mastdata website is very out of date as it still shows an Orange 2G mast near me which was actually decommissioned over 2 years ago now.
by Skilled Contributor
Skilled Contributor
Also remember that TAC & LAC codes can easily change over time with sites being rehosted into different "control areas" (trying to keep this simple) heck even the broadcasted CID could - although admittedly far less likely to.
The various third party websites you've quoted are useful in (accuracy issues all dependent) confirming which operators particular sites are owned by, and their site references. Not a great deal else to be honest. And in fairness, anything else is of no use to the general public and only of use to network-engineering-teams.
by Crunchieeagle Contributor
The only website that gives you some mast location information is mastdata.comBut it is isn't always up to date, but what is there is accurate.
However you can only find mast locations via post code.
Cheers
Russ
