by leo7 Contributor
4G Extremely Slow
The 4G speeds on my iPhone are extremely slow. It is virtually impossible to use the internet. My speeds are consistently very close to 0.1 Mbps.
This happens inside any building anywhere in London. I only get better speeds in parks.
I emailed Marc Allera complaining about the issue (Ref. 13015521). He didn't respond, but I received a response from Travis Brading. He was exceptionally rude and dismissive. He did not address my complaint but bluntly stated that I have signed a 2 year contract and need to pay.
I requested a letter of referral to the Ombudsman but he failed to issue one.
I would like to bring a class action against EE. Contact me if you are experiencing the same issue.
Here is a tiny fraction of all the proof I have of the slow speeds:
https://www.speedtest.net/my-result/i/3286071880
https://www.speedtest.net/result/i/3121887395
https://www.speedtest.net/result/i/3121673696
https://www.speedtest.net/result/i/3121425126
https://www.speedtest.net/result/i/3121322270
https://www.speedtest.net/result/i/3121302881
https://www.speedtest.net/result/i/3119808630
https://www.speedtest.net/result/i/3119770595
https://www.speedtest.net/result/i/3119593599
https://www.speedtest.net/result/i/3119584475
https://www.speedtest.net/result/i/3113515040 !!!
https://www.speedtest.net/result/i/3113352299
https://www.speedtest.net/result/i/3113264340
https://www.speedtest.net/result/i/3113222046
https://www.speedtest.net/result/i/3113142971 !!!
https://www.speedtest.net/result/i/3113048711
https://www.speedtest.net/result/i/3113010146
https://www.speedtest.net/result/i/3112097791
https://www.speedtest.net/result/i/3111933914
19 REPLIES 19
by Expert Contributor
Expert Contributor
Re: 4G Extremely Slow
I get exactly the same issue where i live. During the night speedtests are consistently 100Mbps but during the day 4G drops as low as 3Mbps. Simply put EE are over subscribed and dont have the necessary backhaul / capacity to deal with demand. They wont admit it, and the same will happen to 5G once its been over saturated.
by leo7 Contributor
Actually,  3Mbps is pretty fast. I would be more than happy to get such speeds. Mine are very close to 0. It's impossible to use any app. They all crash and you get partially loaded web pages.
Hi @leo7
Welcome to the community.
I'm sorry to hear that you're having problems with your 4G connection.
I've sent you a private message to get some more information from you.
Please take a look and get back to me.
by leo7 Contributor
@leo7   In your first post you say indoors,  no network will guarantee a signal indoors as buildings your in can block signals.  Would you expect a signal if you was in a basement as it seems you would.
by Star Contributor
Star Contributor
Hi Leo7
I was in London last Friday around Liverpool Street, Bank, Farringdon and Knightsbridge and did not experience any issues like you describe; in one indoor test, 280mbps was achieved.
Yesterday I was in London again, this time at the Excel and then Shoreditch, again not experiencing issues indoors.
Performance does vary, especially indoors, and EE does not provide a guaranteed bandwidth in contract.
by leo7 Contributor
IMG_5372.PNGSpeed Test
by duncanleetedds Established Contributor
Hello Leo7!, have you tried resetting network settings? If that doesn't help try resetting the APN settings.
Here are a few more reasons:
Bill not played
EE network slow because of 5G
You have loads of apps in the background
Or you have personal hotspot on.
Let me know how you get on 😊
by leo7 Contributor
by Brilliant Contributor
ust posting photos isn't going to help.
Also they will not be slowing down 4G for 5G roll out it'll be the same speed as 4G normally is.
Where about are you @leo7 ? There may be issues with the mast in your area.
Hi @leo7
I recommend either replying to my private message or contacting our technical support team.
That way we can investigate what's causing your problem.
by CJ101 Investigator
I live in London, and I drive all around London on a daily basis. And it’s all the same all over London. Slow connection and slow downloads as well as loss of coverage. I can categorically say (with a top of the range iPhone) without hesitation that EE has slowed down 4g since the 5g promotion started.
by Star Contributor
Star Contributor
Do you have field testing log files to evidence such a view?
I have not found any evidence to that effect in my numerous trips to London. However, we have recently had extra hot weather which tends to bring large numbers of people outdoors and using their phones, thereby increasing load.
There is also no plausible technical reasoning to support the suggestion that EE is slowing 4G - 4G on masts typically gets upgraded in fact when 5G is added and 5G devices use 4G and 5G bandwidth at the same time.
by leo7 Contributor
Hi   CJ101
Yea, it's horrible! I constantly perform speed tests as required by EE technical department. The speeds are constantly 0 (zero). I'll start uploading the results but there are several thousand of them .
Hi @leo7
Are the Tech Gurus investigating this for you? It's unusual that you'd get absolutely no connection to mobile data.
by Ravenbrand Investigator
Hi there,
I've been experiencing exactly the same issue, usually download above 50mbps and upload above 20mbps.
Now i'm getting download around 15mbps and absolutely zero upload. Ping is between 15-21ms.
Morning @Ravenbrand
Thanks for posting on the community.
Have you reported this to our Tech Gurus on 150, so they can get this looked into for you?
by Gavalar1
New Member
Same here. Last few weeks it’s dropped to 3MBPS if I’m lucky. Definitely something going on recently. EE used to be good, but way behind now. Partners o2 is fantastic in comparison. Have contacted support but they couldn’t resolve anything. Waiting for a call from some escalation team.
Hi @Gavalar1
Keep us posted on what happens when you get the call.
Chris​​​​​​​
