by glenmavistm Investigator
4G 800mhz
If i purchase a new sim only and install in an unlocked S7 Edge will i be able to use the 800mhz 4g band or will the phone require a carrier upgrade
EE Employee
Solution
Re: 4G 800mhz
Hi and welcome to the Community @glenmavistm
All details on what types of handset can be used for 4G 800mhz and 4G calling can be found in our guide regarding this subject.
Many thanks,
Lee
EE Employee
Solution
Re: 4G 800mhz
Many thanks,
Lee
by Profile closed
Not applicable
Re: 4G 800mhz
You'll get 4G800 data but not VoLTE/4G calling if the phone doesn't have EE firmware.
Re: 4G 800mhz
Many Thanks
Lee
Re: 4G 800mhz
Thanks for the info
