by Andrews Investigator
3G NOT WORKING ON MY PHONE
Hi can anyone help . I am on pay and go and am using a unlocked stk phone. I have data to use, but my phone will not connect using 3G. My data is turned on on my phone. when I try to connect using 3G I get message saying data is turned off, but it is actually turned on. the phone will only use 3G.
Solution
Re: 3G NOT WORKING ON MY PHONE
Hi @Andrews,
Welcome to the EE Community.
Which phone model is it?
8 REPLIES 8
Phone not connecting to 3g network
hi
 Can anyone help I am using a stk unlocked phone and my data  is turned on, but when I try to connect through 3g network, I cannot get a connection and get message saying my data is turned off but it is on.
Are you in UK?
I AM IN THE UK YES
Can you make & receive calls & texts?
Have you checked the Network Status Checker there & logged the problem?
Solution
Hi @Andrews,
Hi James
 I am using a unlocked STK EVO 2 PHONE
Yes
Thanks @Andrews.
Are you able to try your SIM card in a different phone to see if the data works?
This will help us to narrow down the root cause of the issue.
Jon
