by Skilled Contributor
Skilled Contributor
200gb data
I will be calling CS in morning as my EE app says my data allowance is 200gb , pack renewed few days ago .
Any my one else seeing this ??
by Ace Contributor
Solution
Re: 200gb data
HI @Gingerpc
It might be glitch in app.
http://add-on.ee.co.uk
You can check your data allowance with above link.
by Ace Contributor
Solution
Re: 200gb data
HI @Gingerpc
Re: 200gb data
Hi @Gingerpc
Thanks for posting 🙂
Has the advice from @tahirmian helped you today?
Cheers
Richard
Skilled Contributor
Re: 200gb data
Thank you @tahirmian.
yes @Richard_C , was very helpful.
app glitch
Re: 200gb data
Good news @Gingerpc
Pleased to hear that this helped you out.
Richard
Recent solutions
