by Rei
10gb package lhr10 doesn’t work
Hi
I have the same problem now. I bought the sim card at Stansted Airport vending machine and I cannot get 10gb data by texting lhr10.
Can you please help?
Thank you
Solution
Re: 10gb package lhr10 doesn’t work
Hi @Rei
Welcome to the community.
I've sent you a private message, please take a look and get back to me.
Chris 🙂
25 REPLIES 25
Solution
Hi @Rei
Chris 🙂
by Ammar69
Hi I got the same problem I bought the simcard to use the 10gb data but lhr10 is not working and I'm stuck is there any solution or any way to get 10GB data
Hi @Ammar69,
Welcome to the EE Community.
I've sent you a private message.
Thanks Smiley Happy
by fareosama1988
Hello
am also facing same problem
 anyone can help me?
why dont just make the answer public rather then sending private messages.
weird Smiley Sad
EE Employee
Hi @fareosama1988 and welcome to the community.
I have replied to your private message to assist with your issue.
Many thanks,
Lee
by fareosama1988
please recheck. receive nothing until now
by nicknicker12
I am facing the same problem. Please advise on how to enable the 10GB data I have purchased
by Dodianone
Hello,
I bought a sim from heathrow and have been unable to activate the extra 10gb. Please advise how to enable it as needed asap.
EE Employee
Hi @Dodianone and welcome to the community.
I have sent you a private message to assist.
Many thanks,
Lee
by hyung75
New Member
Good morning @hyung75
Thanks for posting in community 🙂
Please take a look here for the answer
Once you have used up the initial 500MB data allowance, your 10GB allowance should be activated automatically.
If it isn't, just let us know and we'll make sure it's added for you.
Thank you
Richard
by Matusval1
Hello Christopher_G
I don’t see any add on activated, actually the page shows the following
message
“You've got some data to get you started.
Your pack will start when that data runs out.”
Also that I have 10 pound credit and a lot of options
Regards!
by Matusval1
Hi
Hi, I am in London till May 23 and bought a 500mb and 150min sim with free 10gb data at Heathrow airport. When trying to activate the 10gb with the code LHR10 to 150 I receive the message ”Unfortunately you are not eligible for this offer. Please check you have an active Pay As You Go pack and have called, text or used data during the lifetime of your pack.". I have tried activating top up card as well but no luck.
Hi @Matusval1
Welcome to the community and thank you for purchasing an EE SIM.
Could you please check our add-on status page and let me know if you have an active data add-on?
by gillismic
I am having this same issue, lhr10 not working, keeps saying it is 'unavailable' for me but that's not what it says on the package I bought...
Welcome to the community, @gillismic. 🙂
Could you try checking the add-on status page please?
Let me know if it shows any data allowance at all.
Thanks 🙂
by gillismic
Hey, it says I have 29mb left of 50 mb... I thought the SIM was supposed to have 500mb to start with... I definitely don't see the extra 10 gb
OK, thanks @gillismic. 🙂
I've sent you a private message to get a little more information from you.
Please take a look at your community message inbox.
by Hemantkg
Please help me too, I got the same issue.
