by Kirdon Investigator
10GB promotion lhr10 doesn't work
It is urgent as I am visiting UK... I bought an EE SIM card @ Heathrow airport, but the 10GB data cannot work! It says "unfortunately you are not eligible for this offer...". Could anyone help investigate into this?
Thanks!
EE Employee
Solution
Re: 10GB promotion lhr10 doesn't work
Hi and welcome to the community @Kirdon
Please use the standard 500mb first as the 10GB should automatically start.
If this does not happen please let me know.
Many thanks,
Lee
47 REPLIES 47
Re: 10gb package lhr10 doesn’t work
Hi @Christopher_G, I got the same problem! I bought the SIM card @ heathrow airport and 10GB data cannot work! It says "unfortunately you are not eligible for this offer". Could you investigate into this? It seems a pretty common problem. Thanks!
EE Employee
Solution
Many thanks,
Lee
Hi @Lee_H, I have used up 500mb but the 10GB does not apply automatically. Could you please look into this? Thanks!
by TinyG0d Investigator
Hello @Lee_H!
My apologies, but I need help as well. I've bought the card from a reliable source in Singapore, and has successfully activated the 10Gb free data upon texting the code. However, I had just received a message telling me that I have use 80% of my data and have 500 mb remaining, unable to check the actual amount of data I have used. However, I had received a confirmation message telling me that the 10 Gb of data is activated already.
May i ask if the data only pertains to usage within the UK, and not the EU? I am currently travelling in Norway, and has used the previous data in this manner as well.
Looking forward to your reply.
EE Employee
Hi @TinyG0d
What is displayed when you head over to http://add-on.ee.co.uk/status
Your data should be usable in the EU.
Many thanks,
Lee
Thank you so much @Lee_H
I now get the 10GB data. Thank you for sending my request to the team.
EE Employee
No problems @Kirdon
I'm glad you are now sorted 🙂
Cheers
Lee
Thankyou for your prompt reply. @Lee_H
Attached are screenshots of the webpage, and my 10gb data confirmation text. WeChat Image_20180524144941.jpgWeChat Image_20180524144956.jpg
Thanks @TinyG0d
As you have received the confirmation that the 10GB has been added to your account, the full allowance should kick in after your current pack expires or the current data is used.
Hi @Lee_H
Sorry for the late upload, my previous image had issues and was removed.
We can see your images here on the community team, even if they're not approved for public, @TinyG0d.
Once your 3GB runs out, your 10GB should start.
Please let us know if you have any problems.
Chris 🙂
Hi @Christopher_G!
Is it safe to assume that the above replies are for me?
Thanks a lot for your help!
Yes, they absolutely are, @TinyG0d.
Apologies, for the community-fail. 🙂
I'll amend the posts now.
Hello @Christopher_G
Many apologies for bringing this up again, but the 10gb has evidently not kicked into usage as I am now left with no data on that card. I've received the message "You have used all the data from your pack. To stay connected get an add-on by texting ADD DATA to 150 or get your next pack now by texting ALL PACKS to 150."
Is it possible to look into the issue for me again?
THanks!
EE Employee
Hi @TinyG0d
I have sent you a private message on here, so I can get some details from you.
Thanks,
Lee
by KYL035
Hi MR. Lee,
I also met the same problem that I can't get extra free 10GB, I bought the SIM card at LHR airport.
Thanks for your support.
best regards,
Adam
Hi @KYL035,
Welcome to the EE Community.
Have you texted LHR10 to 150?
Have you used up the introductory 500MB data allowance?
by lucazanin
I am having same problem. Free 10GB has not kciked in yet after i have used 500mb.
Hi @lucazanin,
Thanks for visiting the EE Community.
Did you text LHR10 to 150?
