by strotch
100 Texts included in Data only sim??
I've just received my 32Gb data sim which I understood was for data only but when looking in my account details it says I have a free add on of 100 text messages! So does the mean EE approve of its use in a Phone or phablet?? Thanks in advance for your help.
by Profile closed
Not applicable
Solution
Re: 100 Texts included in Data only sim??
You are welcome @strotch enjoy your new data SIM! Come back to the community anytime if there is anything else you would like to know. 🙂
by Profile closed
Not applicable
Hello @strotch yes your data SIM plan should comes with an allowance of text messages and no EE do not mind what device you use it in, but there will be no minutes allowance attached so you will pay the full rate for any calls you make from it. 🙂
by strotch
Thanks Tom,
just the reply I was looking for! At £14.50 per month it seemed like the perfect way to get cheap data and being able to use it in various devices is a nice bonus, thanks again.
by Profile closed
Not applicable
Solution
Recent solutions
