Mobile Data
A place to ask questions and share tips about using mobile data.
Forum Posts
EE APN Settings: Where to find them
Hi there, For APN settings please see our dedicated Help page at https://ee.co.uk/help/mobile/fix-problem/Managing-APN-settings. This Help page will give you the link to download the correct APN settings for your device. It will also give you a step-...
Sean_D by Former EE Community Manager
  • 130377 Views
  • 49 replies
  • 20 Helpful
Texting and calls from Italy
Hi, I text ROAMING to 150 and now I’m all set up to use phone in Italy. Just like to check that to make calls and text to UK do I have to have to have mobile data, data roaming ‘on’ or can I keep them turned ‘off’. This may be a basic question, but I...
Mikey52 by Contributor
  • 7 Views
  • 0 replies
  • 0 Helpful
EGYPT- data add ons on landing
Hi, Going on holiday to Egypt have seen on a couple of posts that data add ons will be offered on landing. Can anyone provide up to date prices for this ? TIA
morning
message say addons purchase error we woking on fixing this page 2 day need back normail i cant though for data for my kids and myslef mean cant not txt them how long for problem teachin fix data on mobile i though back normal but did.t work failed ag...
jenny_79 by Contributor
  • 23 Views
  • 3 replies
  • 0 Helpful
Gifted data not showing.
I gifted 2GB of data from one sim to another this morning and it is showing gifted from one but doesn’t appear on the other - I got no text. tried again with 500MB and this time got a notification text but this also hasn’t appeared on the data allowa...
Data transfer
Hi I want to gift data a member of my family how can I do that.
Pa183 by Visitor
  • 24 Views
  • 1 replies
  • 0 Helpful
5g Sim Problem
I just purchased a £15 with 25gb of data sim Today for my D-Link  DWR-978 5g router.Set it up on my phone Setup worked fine. Popped it in my Router and can only get 4g.4g lights up But I cannot get a 5g Light on my Router. And I am only about 1/2" mi...
macsim by Investigator
  • 100 Views
  • 3 replies
  • 0 Helpful
Network down on LTE 5g router
hey, for months I have been using my 5G router as wifi for my pc at home, so far no problems at all very good speeds and everything but then 3 days ago the router can't seems to connect when I'm using my EE sim card. The sim is working fine on the ph...
Aizel330 by Investigator
  • 354 Views
  • 15 replies
  • 0 Helpful
