EE Community
Reply
PatchWrona
Re: My sony xperia sp wont charge or turn on
my pc doesnt even recognize my phone for some reason
Please use plain text.
PatchWrona
[ Edited ]
when i plug my phone in, a noise on the laptop pops up that indicates the usb is plugged in, but then another noise pops up that indicates that the usb has been removed...
Prodigious Contributor
cbarai
Did you try to flash another rom and did it brick the device?
Have you tried reflashing back to stock firmware using the SUS / Flashtools ?
If you think my solution helped feel free to hit the Kudos button below.
New Member
christina95
Hey when you reset your phone by presssing that button did it reset everything? like did you lose you photos and stuff? please help!!
Brilliant Contributor
Chester
Anything on the external SD card should be fine.
Always back up media, contacts etc stored on the internal memory.
